Create basic SPBM and IS-IS infrastructure.
Configure a CLIP interface.
Perform the following procedure to create a virtual NNI link between Multi-area boundary nodes.
enable
configure terminal
interface Loopback <1-256>
If you configure the loopback interface for the Multi-area virtual NNI link in the home area, you must configure IS-IS on the logical interface in the remote area, and vice versa.
Configure a Multi-area virtual link NNI for the home area. To do this, create the loopback source to be redistributed in the remote area and then enable IS-IS on a virtual-link logical interface in the home area.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface loopback 1 Switch:1(config-if)#ip address 2.2.2.2/32 multi-area-virtual-link remote exit Switch:1(config)#logical-intf isis 2 dest-ip 4.4.4.4 multi-area-virtual-link Switch:1(config-isis-2-4.4.4.4)#isis Switch:1(config-isis-2-4.4.4.4)#isis spbm 1 Switch:1(config-isis-2-4.4.4.4)#isis enable exit
Configure a Multi-area virtual NNI link for the remote area. To do this, create the loopback source to be redistributed in the home area and then enable IS-IS on a virtual-link logical interface in the remote area.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface loopback 1 Switch:1(config-if)#ip address 2.2.2.2/32 multi-area-virtual-link home exit Switch:1(config)#logical-intf isis 2 dest-ip 4.4.4.4 multi-area-virtual-link Switch:1(config-isis-2-4.4.4.4)#isis remote Switch:1(config-isis-2-4.4.4.4)#isis remote spbm 1 Switch:1(config-isis-2-4.4.4.4)#isis remote enable exit
The following example displays loopback interface information:
Switch:1#show interfaces loopback
Circuitless IP Interface - GlobalRouter
INTF IP_ADDRESS NET_MASK OSPF PIM AREA_ID IF IP MULTI-AREA
ID STATUS STATUS INDX NAME VIRTUAL LINK
1 2.2.2.2 255.255.255.255 disable disable 0.0.0.0 1344 Virtual-link Remote
2 2.3.4.5 255.255.255.255 disable disable 0.0.0.0 1345
15 192.0.2.2 255.255.255.0 disable disable 0.0.0.0 1358 EXTR
Loopback Ipv6 Interface
IF VRF Descr VLAN PHYSICAL ADMIN OPER TYPE MTU HOP REACHABLE RETRANSMIT IPSEC
INDX NAME ADDRESS STATE STATE LMT TIME TIME STATE
1234 GREEN CLIPv6-11 00:00:00:00:00:0b enable up ETHER 1500 64 30000 1000 disable
Loopback IPv6 Address
IPV6 ADDRESS/PREFIX LENGTH LOOPBACK-ID TYPE ORIGIN STATUS VALID PREF NAME
LIFETIME LIFETIME
2001:DB8:2000::1/128 C-11 UNICAST MANUAL PREFERRED INF INF EXTRSER200
The following example displays logical interface information:
Switch:1>show isis logical-interface
ISIS Logical Interfaces
IFIDX NAME ENCAP L2_INFO VIDS TUNNEL L3_TUNNEL_NEXT_HOP_INFO BFD TUNNEL ORIGIN ISIS SDWAN
TYPE PORT/MLT (PRIMARY) DEST-IP PORT/MLT VLAN VRF STATUS SRC-IP MTU OPER STATE
1 SD-WAN-1 IP -- -- 192.0.2.3 Port1/44 4047 sd-wan disabled 192.0.2.1 ZTF 1400 UP
2 SPBoIP_T1 IP -- -- 192.0.2.15 Port1/25 500 vrf23 disabled 192.0.2.16 CONFIG 1000 N/A
3 SPBoIP_T2 IP -- -- 192.0.2.224 MLT10 2 vrf24 disabled 192.0.2.22 CONFIG 1600 N/A
4 Virtual-link-4 IP -- -- 4.4.4.4 PortRX-NNI 4051 GlobalRouter disabled 2.2.2.2 CONFIG 1600 N/A
5 Virtual-link-5 IP -- -- 5.5.5.5 Null 0 GlobalRouter disabled 2.2.2.2 CONFIG 1600 N/A
5 out of 5 Total Num of Logical ISIS interfaces
